1 - 20 of 30 Posts
Like the title says i am looking for the best power adder to go with for this class i am going to run. The engine will be a BBC in a 2000 mustang with 29.5 X 10.5 tires.The fastest car in the class has been a 5.08. Any help would be great thanks in advance. Here are the rules for the class.
True Street for 2008
Factory body with stock firewall, must run mufflers
Fiberglass limited to hood, decklid, bumpers & fenders
Full interior with stock appearing dash & two front seats
Factory glass windows and must be operable
Stock frame rails from front to back, rear rails may be notched
Any bolt-on front suspension parts allowed**
Rear suspension may be bolt-on stock-styled or ladder bars
Rear leaf springs may be moved inboard
Mini-tubs and coil-overs are allowed
Rear wings are allowed
No clutchless transmissions
No wheelie bars
Maximum slick is 30X10.5 (10.75 as measured) or a 12.5 DOT (11” as measured), NO “W” tires allowed
Sheet metal intakes are permitted
WEIGHTS:
V-6 Turbo – 2900 lbs
Sm Block V8 N/A – 2550 lbs
Sm Block V8 NOS – 3000lbs Single Stage Plate
Sm Block V8 Supercharged – 3150 lbs
Sm Block V8 Turbo – 3200 lbs*
Big Block N/A – 2750 lbs
Big Block NOS – Single Stage Plate – 3300 lbs
Big Block Supercharged – 3300 lbs
Big Block Turbo – 3300 lbs*
All 1978 & older cars plus all G bodies and Leaf sprung cars & trucks may deduct 100 lbs if using stock suspension
Add 100 lbs for the use of a single fogger
Add 50 lbs for any nitrous plate that drops below
the top of the intake plenum
Add 200 lbs for the use of a second plate system, 150lbs on sm blocks
Add 75 lbs for the use of stand-alone EFI (DFI, Fast, etc.)
Add 75 lbs for the use of water to air intercoolers
Add 200 lbs for dual carbs
BOP powerplants run at small block weights
Add 100lbs for use of Alcohol
*Turbos & superchargers limited to 4” inlet & outlet on EFI, 5” inlet & 4” outlet on blow-through carbs… 88MM maximum, larger turbos will be required to run a smaller inlet restricter, 3.50” inlet for 88-94MM impeller, 3.25” inlet for 94MM and up impeller.
** Front suspension may be upgraded as long as it is for stability and not for weight reduction purposes and retains original design, tech reserves the right to add a weight penalty if necessary.
the 88mm will be too small to be efficiant on just about any big block, I'd lean more towards the Procharger. Especially if they'll let you neck down an F2 or F3 to meet the 4" inlet requirement.
If not I'd look at going with the 94mm with the 3.5" restrictor, probably the best overall fit for the turbo option.
How fast is the class to begin with
Sounds Like
Sounds like our Extreme Street class here. With the exception of strict 29x10.50 tire and they allow wheelie bars. Also only one nitrous kit allowed. Pretty well dominated by nitrous cars, but turbos can be competitive too.
Fastest pass as far as I know is 5.19 @ 135 and some change. Big Block Chevy powered first gen Camaro.
540ci supercharged pontiac on alcohol. (they can run @ small block weight)
hey z289sec; riggins's camaro has a SMALL block. yikes!
hmmm! ???ci pontiac with a plate 3000lbs.
substitute a fogger=3100lbs.
deduct 100lbs for '78 fairmont stock suspension=3000lbs
where is this class going to be run?
Damn!!! I thought it was a big block!
When I read those rules and saw BOP's race at small block weight, you are the firsy guy I thought of. You could make a killing at that race!
i don't think i could get my car light enough with the no-lexan rule since mine has a mild steel cage. but if someone were to build a fairmont from the ground up then.........
If you build a turbo car right it could compete. Does it say where you have to put the restricter at on the larger turbo sizes?
1 - 20 of 30 Posts
