1 - 1 of 1 Posts
Looking for a trans recommendation. 3200 lbs, tall deck 540 (will grow in the future), 29.5 slick, stock style 4th gen f body susp. Motor is over 850 n/a and will primarily be run with 1 system but it has a 2nd system to turn on for grudge events, etc. wheelie bars are on all the time. Rear gear can be whatever, have 3.73 and a 4.10 set but will have this apart installing new axles (40 spline up from the 33 that are in it now) so anything can go in, braced up 12 bolt housing)
Looking for a trans recommendation. Something that's not going to break, fail, etc. I was thinking a 1.69 glide, the longer 1st should make for a more consistent setup with varying track conditions but I'm open at this point.
What would you go with and why?
1 - 1 of 1 Posts
