Well, we are running, and working to the point so we can say we agree that we have a good tune before we turn on the system.
I'm running a direct port system (NX) stand alone fuel system, will be a 100 hp shot, Mallory 685, pump gas sbc, stock 010 block, extensive work done on the iron heads. Other than that I don't know what the motor is. It seems to be running pretty good at 38 deg timing dist locked, although I'm still experimenting on that so It could be a little more or a little less.
I am wondering about a couple things before we pull the trigger on this.
On the 685 settings. Window switch, would 2500 to 6000 be good? I have set the rev limiter at 6500.
Nitrous fuel. I think I have access to 110 maybe even C12 thru C16 but i am not sure on that so I am hoping 110 will do.
Timing. Will I be safe starting out taking out 6 deg to start?
Plugs. I have no idea.
This engine is what we had to work with to start him out as he plans to run a big block when he gets comfortable with the nitrous system. But I would like to keep from scattering this engine first time on the bottle.
And suggestions from you guys would be great.
