1 - 3 of 3 Posts
Alright guys, I'm looking at. Hung a truck to pull the racecars, and drive back and forth to college.. Came across this truck on Craigslist, but I'm worried about the transmission. I'm not a diesel guy by any means, so any feed back is appreciated.
Here's the add:
it is a 95 dodge 3500. 2wd. automatic.
motor mods: 4 inch exhaust turbo back, 7 or 8 inch tip, new lift pump, completely shaved fuel plate, pump is timed, bigger fuel transfer lines, 100hp injectors, 3/4 cut delivery valves, fixed kdp, new front cover, 66mm holset turbo, shaved heads not studded though, im sure there is something im not remembering!
tranny mods:rebuilt 2000 miles ago, billet torque coverter, new clutches throughout the tranny, modified valve body, new relays, lock-up switch, overdrive timer, 410 rearend.
6 new tires all way around, yokahoma geolanders. new wheel bearings on the front, rebuilt front end. hid headlights, led taillights, led running lights, 3 guage pod(egt,fuel pressure,boost), dash is busted(not unusuall for dodges), captain chairs and wood console. i was working on repainting the truck and ran out of money, boddy is in good shape. have two new fenders and a tailgate to go w the truck
A 66mm turbo (if it really is one) won't tow worth a damn on a 12v... Also the pump mods might make it a poor tow rig too depending on the details.
I'm not sure about that turbo... Only holesets I've seen have been 60s (somewhere in that area anyway) good to know about the pump, too.
1 - 3 of 3 Posts
