1 - 4 of 4 Posts
If you have the 97 corvette rails There may be some options. Otherwise you will have to go regulator before the rails.
the best way to do it is to put a set of aftermarket rails on, then you can run any regulator you want (run right off the rail if you want, or moutn wherever) and you can use the fuel tank vent line that runs up to the intake on the drivers side and just ditch the evap junk and use that line as a return, unless you're already on an aftermarket tank in that case another -an line to the tank.
1 - 4 of 4 Posts
