1 - 1 of 1 Posts
I am in the middle of hooking up my little wizard delay box. Have not connected it to power or ground yet. I was wiring a weather pack connector to the inputs when I found that PB 1 and the ground connectors have continuity to each other. Is this normal. PB1 will be connected to the TB button and should receive the 12 volts from the TB button to initiate the sequence of the box. Confused.
1 - 1 of 1 Posts
