1 - 6 of 6 Posts
got a limited street nitrous car with ladder bars what would be the advantage or disadvantage to lowering the ladder bar down a hole in the front will it hit the tires harder ect any info would be appreciated
you will also be shorting the instant center, will {shock} hit the rear tires harder, may also cause the front end to lift on take off because of instant center being shorter.
T/S 368E
My ladder bar car also hits softer when you lower the bar. Less wheelie.
You probably missed it, but this is a ladder bar car, not a 4link. The instant center is at the ladder pivot, so lowering the pivot lessens the rear end rise, separation, or "hit," as it's normally defined.
the higher the bar the higher itll hit the tire. like mrdragster said. middle hole on bars skipd slightly and leaves, top hole and seems to carry the wheels a little farther but owuld also improve the 60ft a consistant .03
1 - 6 of 6 Posts
