1 - 20 of 61 Posts
http://www.racedxp.com/classes-rules/x275/
(CURRENT X275 RULES WILL APPLY)
$7,500.00 WINNER
$1,000.00 RUNNER UP
$400.00 SEMIS
$200.00 1/4'S
TECH CARD $200
SECOND CHANCE RACE
FOR 33RD AND DOWN
$1,000.00 WINNER
BODY:
The car must retain its original appearance, profiles, and dimensions. Factory roof and quarter panels must be used. Aftermarket fiberglass and/or carbon fiber replacement panels are limited to hood, front fenders, doors, deck-lids, and bumpers only. All front ends must be of factory dimensions and cannot be lengthened and must meet all NHRA/IHRA height. (See ground clearance note below). Any beam tripping devices forward of the bumper are prohibited. (Track tech official will have final say) Aftermarket wings and spoilers are permitted. Complete stock appearing front and rear bumpers are required. A hood must be used: scoop or hood must cover the entire induction system. Forward facing hood scoops/ turbo or supercharger inlets are permitted.
GROUND CLEARANCE:
Minimum 3 inches from front of car to 12 inches behind centerline of front axle, 2 inches for remainder of car, except oil pan, oil retention device, and headers.
INTERIOR:
Factory appearing dashboard, door panels, and driver seat is required. Full Carpet is required on floorboards including transmission tunnel. Factory floor pan on driver and passenger side required from firewall to rear of door jamb. Transmission tunnel maybe removable and must be metal. Bare inside frame of car cannot be exposed. Aftermarket steering column is permitted.
WINDSHIELD/WINDOWS:
OEM glass or Lexan windows are permitted.
CHASSIS:
Complete stock chassis and frame rails must be retained from motor plate/shock tower to behind the rear wheel opening. Back-halved cars are not permitted. Front core support may be modified or removed. Aftermarket bolt-on replacement front K-members/sub frames are allowed (if front shocks bolt to K-member then they must be in factory location). Shock tower can be notched or trimmed but must be in factory location, verifiable by the factory sheet metal being retained between frame rail and top of tower. Mini tubs are allowed. Rear frame rails may be notched for clearance and must be in the factory location. Factory wheelbase must be maintained. (+ or – 1 inch)
ENGINE:
Maximum displacement for all engines is 588ci. Small blocks are allowed any deck height but must retain stock bore spacing. Big block allowed the following deck heights but must retain stock bore spacing. GM Big Blocks are limited to a 10.2 deck height. Ford Big Blocks are limited to a 10.3 deck height. Mopar Big Blocks are limited to a 10.7 deck height. (Cylinder head specs and list for BB Nitrous Combos to be released- billet blocks prohibited)
TURBOCHARGERS:
Single turbocharger limited to 88 mm maximum. (Garrett GT55-88, Exile ETR-88, or = Forced Induction, Comp, Bullseye - mid frame or current (2013) PTE Pro Mod MF88, PTE LF85 or LF88 turbos only). Turbocharger size will be verified by measuring the housing bore at the leading edge of the impeller wheel and must maintain the contour of the compressor housing. (Stepped or Clipped compressor wheel prohibited) Inducer dimensions will not exceed 3.462 inches and Exducer dimensions will not exceed 4.765 inches on MID FRAME turbos. Inducer dimensions will not exceed 3.462 inches and Exducer dimensions will not exceed 5.56 inches on LARGE FRAME turbos. The maximum diameter of the housing bore at the leading edge of the wheel may not exceed 2 mm more than the maximum allowable turbocharger size permitted. Inserts or reducers to achieve inlet or outlet dimensions prohibited. Any type of air to air or water to air intercooler permitted. Turbochargers w/nitrous-oxide prohibited except on 2-rotor, 4 cylinder, and inline 6 cylinder engines.
SUPERCHARGERS:
Cog or gear driven superchargers are permitted, must meet all factory inlet, outlet, and internal housing dimensions. Inserts or reducers to achieve inlet or outlet dimensions prohibited. Any type intercooler is permitted. Supercharger cannot be combined with nitrous oxide. Roots superchargers are limited to a 10-71. Centrifugal superchargers are permitted. Screw superchargers are not permitted.
NITROUS OXIDE:
Small block is permitted to run any type multi-stage nitrous systems. Big blocks are limited to a single stage nitrous system with single -6 line(**see below for accepted line) to fogger single wye
to -4 line(**see below for accepted line) connected to fogger solenoids or single -6 line (** see below for accepted line) to plate solenoid(s) – A single stage fogger (2 nitrous solenoids and 2 fuel solenoids) are permitted or if using a single plate then your limited to (1 fuel solenoid, 1 nitrous solenoid), and 1 purge solenoid, purge must exit engine compartment. Small block nitrous are permitted water injection. EFI Big Blocks will only be allowed 2 nitrous solenoids for a dry nitrous system and will only have 1 line per nozzle/per cylinder. (Using both sides of the fogger nozzle on a dry EFI NOS BB combo are prohibited)(Push systems prohibited on big block combo and permitted on small block combo) All lines on big block combo must be visible and continuous from bottle to wye without interruption.
TRANSMISSION:
Any factory style automatic transmission allowed. OEM factory style manual transmission allowed. Bruno-Lenco transmissions are prohibited. Aftermarket clutch-less manual transmission and clutch assisted manual transmissions are permitted on naturally aspirated and nitrous small block combinations only. Electric shifters or air shifters are permitted.
INDUCTION:
Small Block combinations may run any type induction. Big Block combinations are limited to a dedicated single opening cast intake with a single carb or a single 4150 or 4500 series throttle body. (4 blade, dual blade or single blade throttle body permitted).
OILING SYSTEM:
Dry sump oiling systems are permitted on all cars
EXHAUST:
Mufflers or inserts are required on all cars except for turbo cars. Exhaust may exit underneath car or out the front fenders but must not affect timing or staging beams.
FUEL:
Gasoline only is permitted. Alcohol/E85 permitted on roots blown/V6/Inline-6/4cyl applications.
Alcohol or E-85 or other derivatives is prohibited on all other combinations. Meth injection prohibited. Water injection permitted on SB NOS combos only.
STREET EQUIPMENT:
Functional headlights, taillights and brake lights required. All headlights, brake lights, etc. must be on car and not removed for any reason. All vehicles may be towed back from their passes.
SUSPENSION:
Stock style or ladder bar suspension cars only. Aftermarket four links are prohibited on all cars. Aftermarket direct replacement components such as: front control arms, rear control arms, front coil over shocks, and rear coil over shocks are permitted. Aftermarket rack and pinion steering allowed. Rear leaf springs, springs, shocks, and coil-overs may be moved to accommodate tire clearance, and do not need to be mounted in stock location. Bolt-on or welded sub-frame connectors, rear sway bars, are permitted on all cars. Wheelie bars are prohibited on all cars. Torque arms are only
permitted on cars that were originally equipped from factory with it. (see notes below) Upper and Lower control arms must be mounted in the factory chassis locations -S Box permitted.
TIRES:
All cars with power adder must compete on a Drag Radial type tire with the following sidewall designation 275/60/15. Naturally aspirated combos are permitted to run a 28.0” x 10.5” slick,
no “W” tires permitted.
Minimum base Weights:
All minimum weights include the driver.
Naturally Aspirated (small block) 2500 lbs.
Naturally Aspirated (big block) 2700 lbs.
Nitrous (small block) 2700 lbs.
Nitrous (big block single stage plate any deck height & conventional heads) 3250 lbs.
Nitrous (big block single stage fogger standard deck height & conventional heads) 3350 lbs.
Nitrous (big block single stage fogger with tall deck height and conventional head) 3400 lbs.
Single YSI / F1A/6-71 Supercharger (small block) 2800 lbs.
Single F1C/8-71 Supercharger (small block) 2900 lbs.
Single F1R/Xi/10-71 Supercharger (small block – *mod motor or with stock valve angle heads) 3000lbs (add 100 lbs. for billet Xi) (deduct 50 lbs. for 8.2/8.7 deck)
Single F1R/Xi/10-71 Supercharger (small block – any cylinder head) 3100 lbs. (add 150 lbs. for billet Xi) (deduct 50 lbs. for 8.2/8.7 deck)
Single F1X/XB105 Supercharger (small block – *mod motor, LS 15* or with stock valve angle heads cast head only) 3250 lbs. (deduct 50 lbs. for 8.2/8.7 deck)
Single F1X/XB105 Supercharger (small block - inline head) 3350 lbs. (deduct 50 lbs. for 8.2/8.7 deck)
Single F1X/XB105 Supercharger (small block - non-inline head includes SB Mopar SVA hemi style) 3450 lbs. (deduct 50 lbs. for 8.2/8.7 deck)
Single 76mm T6 Turbocharger (mid frame GT47 based) (small block) 2700 lbs.
Single 80mm T6 Turbocharger (mid frame GT47 based) (small block) 2800 lbs.
Single 83/85mm T6 Turbocharger (mid frame GT47 based) (small block) 2900 lbs.
Single 88mm T6 Turbocharger (Y2K or GT47-88 ) (mid-frame) (small block) 3000 lbs.
Single 88mm T6 Turbocharger (GTX55-88 ) (small block - mod motor or stock valve angle cast head) 3250 lbs. (deduct 50 lbs. for 8.2 deck)(deduct 150 lbs. for GTX55-85)
Single 88mm T6 Turbocharger (GTX55-88 ) (small block - any head) 3300 lbs.(deduct 100 lbs. for GTX55-85)
Single 85mm T6 Turbocharger (Large Frame 85) (small block – mod motor or stock valve angle cast head only) 3200 lbs.
Single 85mm T6 Turbocharger (Large Frame 85) (small block) 3250 lbs.
Single 88mm T6 Turbocharger (Large Frame 88/PTE Pro Mod MF88 ) (small block – mod motor or stock valve angle cast head only) 3300 lbs.
Single 88mm T6 Turbocharger (Large Frame 88/PTE Pro Mod MF88 ) (small block cast head only)
3400 lbs.
* Small Blocks (NOS & N/A) with single 4150 carb/throttle body: deduct 50lbs
*Small Block (NOS) with any plate nitrous system: deduct 50lbs (deduct does not apply if used in conjunction with fogger)
* Small Blocks (NOS & N/A) with 23 degree Chevy heads, 20 degree Ford heads, and 18 degree
Mopar heads: deduct 100 lbs. RR - 75 lbs.
* Small Blocks (NOS only) 18–10 degree valve angle inline head: deduct 50 lbs.
* Small Blocks (NOS only) cast t-ram/sheet metal/2 carbs or 2 throttle bodies: add 50 lbs.
*Throttle Bodies exceeding 4500 series on Big Block combinations: add 50lbs
* Non-Intercooled boosted cars on gasoline: deduct 50 lbs.
* Belt driven centrifugal superchargers: deduct 50lbs.
* Aftermarket rear suspension COPO Chevy and Drag Pack permitted on the new Camaro and Challengers must be mounted in exact factory location on body/frame. Torque arm on late model GTO/5th gen Camaro. Corvette with any leaf spring suspension permitted.
* Buick/Olds/Pontiac Nitrous combos will be 3150 lbs. and not to exceed 588 cu inches
* V-6/Inline 6/4 cylinder Turbocharged/Supercharged/Nitrous combos will deduct 250 lbs. from base weight on gas and 150 lbs. if on alcohol
*Factory IRS deduct 50 lbs.
**-6 and -4 nitrous line(s) must be of standard braided line construction,
(high pressure hydraulic line prohibited as they exceed the internal diameter of industry standard)
Standard spec lines/fittings only.
Lines
-4 I.D. .153 to .154
-4 I.D. with -6 Nut .153 to .154
-6 I.D. .275 to .276
Big Block Chevy Cylinder Head:
Conventional Heads as referenced to the original Mark IV design. (BBC symmetrical or raised port design is not defined as conventional for these rules)
- Stock port location/Standard port location – no raised runner
- Floor of port may not be more than .550 from deck
- No port plates or intake manifold adapter plates permitted
- No epoxy or welding permitted except for repair in chambers or between cylinders
- No welding of tops of runners except for adding bolt bosses for rocker stands
- Intake valve angle will measure 24* + or – 1*
- Maximum dimension allowable from deck surface to the top of the intake port will be no more than 3.125”
- Heads with “AS CAST” intake port lower than this dimension will be permitted.
- No welding or epoxy permitted to achieve this dimension.
- Tech official has final say at the time of inspection on any issues that may arise
Suggested castings to include the following:
• CFE/BMF 350 – 405cc Big Block Chevrolet
Chevrolet Factory OEM Iron & Aluminum; OEM Aluminum
• Brodix BB-1, BB-1 OEF1, BB-2, BB-2X, BB-2 Extra, BB-2 Plus, BB-3, BB3X, SR23 (non-raised runner Head Hunter)
• Edelbrock Victor & Victor CNC, Edelbrock Victor Jr. CNC Oval & Rect
• Edelbrock Performer RPM 454-O, 454-O, 454-R
• Edelbrock Victor 24-degree Rectangular Port #77419, #77409
• Edelbrock RPM XT Rectangle PN#51539
• Edelbrock RPM XT Oval PN#51459
• Edelbrock Victor PN#61409
• Edelbrock Victor PN#61419
• Edelbrock Victor PN#77609
Pro – Filer Sniper and SniperX 290 cc 320 cc and 375 cc
• Dart Pro 1 310 cc thru 355 cc, Race Series 265 cc thru 360 cc, Dart 380 Pro2
• Canfield Big Block Chevy 24.5-800, 24.5-900
• GMPP Signature Series BB Heads cast # 12363401, 12363391
• Air Flow Research 265, 290, 305, 315, 325, 335, 345, 357, 385, Oval, Rect & CNC Port
• World Products Merlin II Oval & Rect Port 269, 320, 345, 305, 350 Iron & Alum
• (RHS)Pro Top Line Pro Thunder 320, 360 cc Alum & Iron
Big Block Ford Cylinder Head:
- Factory cast Iron heads (don’t think we’ll see many of them )
- A-429 Cobra Jet (Ford Motorsports)
- Cobra Jet (Blue Thunder, Trick Flow)
- Super Cobra Jet (Ford Motorsports, FRPP/Kaase)
- Blue Thunder “B” head
- Street Heat (Trick Flow)
- Edelbrock RPM
- P-51′s (Kaase)
- “A” designation heads (All manufacturers, Ford Motorsports, FRPP, Trick Flow,
Eliminator, EX514, etc. . .)
Big Block Mopar:
B-1 style cylinder heads only
If one combination appears to have an advantage rules may be changed at the race director’s discretion in order to keep a level playing field for all competitors.
SEE ALSO: EVENT / RACE INFORMATION
Totally defeats the purpose of X275. Promoters running different rules from whats on X275.net makes no sense to me, call it 275DR like Cecil does and adjust as necessary but this isn't X275 to me..
It is x275 rules.
Look at the first sentence in Duck's rules:
It is x275 rules.
Not according to X275.net, weights are different from almost every combo. Leaving the house guessing at which weight to run is rediculous. Feel bad for anyone with a SBNOS combo who spent money to lose weight only to get it added back with these rules...
Damn you quoted me before I edited it :)
First sentence says (CURRENT X275 RULES WILL APPLY)
That trumps whatever's underneath.
Then they should post (CURRENT X275 RULES WILL APPLY) visit X275.net for more info.
Why even post anything if they are wrong? :p
Just got off the phone with Donald
It's the current rules that are on X
I. E. BBNOS 3250
So they (or he) put a 100lbs back on SBnos base weight?
See the payout is down to $7,500?????
1 - 20 of 61 Posts
