50MM cams are pretty common I rarely see bushing work any more as about 95% of the Little=M blocks I machine the customers go to a .904 lifter and no need for a bushings.dart little m , what is everyones suggestions on bronze bushes for lifters .50 mm cam and a morel ultra lifter , where should the oil band be vertical or horizontal ?and has anyone used darts own bushing?
pm sent50MM cams are pretty common I rarely see bushing work any more as about 95% of the Little=M blocks I machine the customers go to a .904 lifter and no need for a bushings.
I use all CHE bushing if needed.
Why is that?Little=M blocks I machine the customers go to a .904 lifter and no need for a bushings.
Why is that?
