1 - 5 of 5 Posts
· Registered
First, the particulars
SBC, 4.156x3.760 (408), light rotating components, 11.65:1 compression, Comp 259/266 tight lash solid FT cam, .586/.608 lift w/1.6 rockers, Ported Iron Bowtie heads, flowing from .100 to .600 lift, 1n/ex:
95/79
148/125
200/174
243/211
255/226
262/226 CFM @ 28" water, flow stalled but not reducing above .600, only one intake and one exhaust port flowed so the other 14 ports ???
Edelbrock Vic Jr, port matched (any easy power gained with plenum porting, possibly step up to a Super Vic?) 1 inch open, 1 inch 4 hole, 850 Holley D/P, Hooker 1 3/4 super comp headers, 3 inch exhaust w/2 1/2 H pipe, 3 chamber flowmasters, no tails, crank scraper, windage tray, 5 qts oil in 7 qt pan, 8 inch 5500 stall (can be reworked to match new cam), TH350 trans (footbrake), 4.10 gears (will be going to 4.56's later on) 9x29.5 MT slick.
The car is a 79 Camaro weighing about 3650 with me and ballast in the trunk (would like to lose the ballast) and it runs in the 11.3xx range at 117 to 118.5 MPH with 60' times in the 1.55 to 1.6 range depending on track condition. Shift points are currently 6800 1-2 and 6600 for 2-3, trap RPM is 6300.
The plan is to have the heads angle milled, shooting for a final compression ratio close to 13:1 (race gas only, no nitrous) and I would like to step up to a larger flat tappet cam that will soften the launch a bit for traction and pick up the power in the 6000 to 6800 range for MPH and ET gains.
Any questions or suggestions?
Thanks,
Doug
· Registered
79rustbucket79 said:
11.65:1 compression, Comp 259/266 tight lash solid FT cam, .586/.608 lift w/1.6 rockers, 8 inch 5500 stall (can be reworked to match new cam), Shift points are currently 6800 1-2 and 6600 for 2-3, trap RPM is 6300
Do you know what the IC/EC are?
Have you ever checked the cranking compression?
Have you ever checked the flash speed of the convertor?
What is the valve lash COLD?
What does it go to HOT?
Do you know the specs on the valve springs?
Right off of the bat it appears to me that there is a miss match in convertor vs gearing vs cross RPM.
See if you have that other information. I would like to know that before I shoot something stupid out.
· Registered
Discussion Starter · #4 ·
-->Valve timing @ .020" Int open 38 close 70, ex open 74 close 42
-->Not recently, but last recollection was 225 PSI, I can recheck if that would help
-->Flash stall is 5500 according to my playback tach
What is the valve lash COLD? .020/.022
What does it go to HOT? .018/.020
-->Springs are 987-16 Comp, 135 # seated, 325 # open, give or take a bit. They are rated at 344#/inch
Before seasons start next year, converter will be "tightened up" by roughly 500 RPM, and rear gears will be changed from 4.10 to 4.56 in order to get the car off the line better and get the RPM to 6800 or so through the traps. If I put the trans in 3rd (full manual) and cram on the brakes I can get the converter to hit 5800 within a second.
1 - 5 of 5 Posts
