1 - 12 of 12 Posts
2350lbs 25:1e
9.5" 3.70 gear.
BBC twin 88mm
Lenco with brunodrive or pro mod PG??
Looking for a low maintenance gearbox.. Will only do about 40-60 passes a year if that matters?
If you want a low maintenance trans go with a clutch and 3 speed CS1 IMHO.
What about ET? 200 is right around the 6.90 to 7.00 mark. Does that sound about right? Depending on tire size , I would go with a 2 speed T400 or a glide depending on what you want and what will properly fit the car.
Hutch
Discussion Starter #10
Hutch
That sounds right.. Tire size is 33x15x15. I have set the car up for a glide, but have been offerd to buy a cs1 lenco 3-spd. Don't really like clutches.. So maybe I should stick to the plan and go with a glide..
1 - 12 of 12 Posts
