Have a quick question. If you had a very lean condition running alcohol would it burn the strap off a plug or have a popping out the exhaust before and engine damage. Reason I ask is My o2 sensors are installed in the collector. The car will repeat numbers in the 1/8 & in the 1/4 mile. I am picking up less than 10 degrees of water temp in a 1/4 mile run. I have no engine popping, plug straps look good & the engine is pulling hard all the way through but..... my o2 readings in the 1/4 mile are 6.5 or higher. I have a front mounted fuel cell with a Magnafuel Prostar 500 pump. 12 to 10 to 8 lines to carb. Apd 1050 Carb. I just think maybe I am getting false readings
