So, I bought a dual gauge leak down tester from Jegs. Both gauges are identical. They just show the psi. The instructions are a little blunt. " Regulate the air pressure atleast 10 psi lower than the source. Subtract the right gauge from the left gauge to calculate the percentage."
The motor is a 10.5-1 compression ratio, 400 ci sbf.
Bore 4.1268, Ross blower pistons 4.1209 top ring gap .026 bottom ring gap .027
Compression is 90 psi on 1 stroke and 130 psi after 4 strokes consistant on all 8 cylinders.
When I tried to do a leak down test at the (per instructions)reccomended psi of 75 psi at tdc it shoves the piston down. I put all the plugs back in except the cylinder tested to aide in keeping the piston at tdc.
Did the test at 75 psi and at 40 psi with a consistant reading on all cyninders with a loss of 10 psi. All the air is going into the crank case. No leakage into the coolant, intake or exhaust. Is this acceptable for a F1r blower motor and how do I calculate this percentage?
