Alright We are currently finishing up installing a rear-end in my car. So I stopped by to take a peak at how it's coming along. So I noticed the passenger side leaft spring is Crooked. It is like the spring perch need to be welded over towards the tire an inch or so. So if your standing behind the car. You look at the driver side it looks nice and straight. Then you look at the passenger side and the leaf spring looks crooked. The shackle is in the right place cause it can't go anywhere but where it is mounted. The the spring goes to the left where it is located on the spring perch. I don't know what it looks like where it goes on the frame in front of the back tire and spring perch.
I drew this up in autocad. It looks bad excuse by poor drawing. But it is showing you a top view of the leaf spring.
Is this bad. And how will affect my car.
