1 - 5 of 5 Posts
i built a new blower motor for my 69 camaro a need to get a new converter to match wondering what rpm will work best to launch at
weight 3200 this is some info about my car. i race @ 1/4 track
powerglide 1.80
4.29 rear
4-link
33" tire
1295 peak tq @4900 and stays above 1200 till 6200 rpm
1500 hp peak
i am planning on shifting @ 7500
Depends on the stall you get built into the convertor. Mine stalls a bit over 5,000 and I like to launch off the T brake at 4,400. Shift at 6,500, trap at about 7,450. Call your convertor builder, or better yet call several of them and compare their advice. Good luck.
-Tanner
We use a spragless 10" from Trans Specialties. Stalls at 3000-3500 depending on how much boost. We leave from 1200-2000 against the brake. 3450 lbs, best 60' so far under 30 PSI of 1.25 without an anti-roll bar.
We'll see how much it increases with the ARB...
1 - 5 of 5 Posts
