1 - 1 of 1 Posts
We stock late model fuel injector fittings. These fittings allow you to convert your 3/8" or 5/16" steel factory line to an male flare fittings.
We have two styles available. One design allows you to push the fitting over the steel line the same as a factory quick snap connection . We stock this style in straight and 90 degree. They are available in -06 and -08 male flare.
The second design screws together for a more secure connection.
These are also available in -06 and -08 male flare
These fittings are available for immediate shipment.
http://www.performanceplumbingcomponents.com/products/an-to-female-quick-connect-90-degree
http://www.performanceplumbingcomponents.com/products/an-to-male-quick-connect-90-degree
http://www.performanceplumbingcomponents.com/products/sae-quick-connect-efi-adapter-fitting-threaded-cap-screw-on-style
1 - 1 of 1 Posts
