1 - 6 of 6 Posts
Master Fabricator
I have the Milodon 12700 gear drive and they include a laminated thrust washer which peels apart in .003 parts.
How in the hell do you peel it apart?
Thanks.
i used a paper clip with a sharpened end to get it started. its a pain in the ass and several times it came off at .006 intervals.
Master Fabricator
I did some research on how they were made. They are held together with a resin. So I use my heat gun to warm up the resin and they peeled like a hot knife through butter.
I was able to peel .003 with no problems...
Thanks for the reply.
Master Fabricator
Milodon said to set the thrust clearance from .000 - .005, I set it at .003. I figured there would be some expansion with heat.
What do you guys think?
1 - 6 of 6 Posts
