1 - 3 of 3 Posts
Havent done this in a Looonnnggg time and need a refresher.
Starting from scratch.
Center hsg with locater
Adjust lower bar of ladder length equal distance and neutral so bolts slide in the crossmember.
Set coilover springs equal distance apart.
Install driver (me) and scale?
Install the Driver before you neutral the bars..
But you will need some preload if it is in the high 8's to mid 9's and slower... (it depends on power weight and tire at what point it will need some preload) if it has alot of power you could need some negative preload.
car will run 10flat about.
scaled it last weekend but due to a miscomunication the rear wasn't centered in the body and the rear springs were set differently.
The pass side spring is compressed an 1" more.
The weights are this.
914DS front 863PS
714 rear 660
1 - 3 of 3 Posts
