1 - 5 of 5 Posts
I have a 1979 camaro weighing @3400 lbs w/driver with ladder bars from "art" and it has strange shocks on the rear with single adj. and the springs are 150s pinion angle @ -2 degrees ... I was at a true 10.5 race I was running on 29.5x10.5. mY setup is 565 with 18 degree dart big chief pro 1s, nitrous pro 2 stage plate 225 first stage .. i have no progressive controllers... I couldn't hook at all with the first stage...my sixty foots were 1.35 it would spin them bad @ .1 with digiset..need help on what i can do to get it hook on true 10.5s... I usually run on the 29.5x10.5w my sixty foots are 1.20 and goes 5.30 with a 325 shot single stage...i seen people run 600hp shot off the line on true 10.5s and they sixty foot 1.25 or better...:confused:
Which tire are you switching to from the 3062W.. the 3062 or the 3062S?
You lost 1" in tire tread width and gained 1 inch of rollout..
I honestly cant remember if the 3062 or the 3062S is the same tire only smaller than the W.. my first guess would be is that you are on the tire that is not same construction type as the W..
Do you have any video? My guess is it is crushing the sidewall,
Call MT and see if the S tire is more similar in sidewall strength to the W than the 3062 tire..
i'll try to post a video if i do its a 1979 red camaro it says 1/4 mile killer on the scoop
1 - 5 of 5 Posts
