1 - 5 of 5 Posts
If on the initial hit the car drives to the right, (assuming everything else is adjusted correctly) do I lengthen or shorten the passenger side adjuster to make the car go straight? Thanks...
Banned
If all-else is fine (like rear tire roll-out side to side) rear springs, shock settings, etc............Making the pass side longer will put preload in it to help it not move to the right off the line.
Is the adjuster on the top or bottom bar?
1 - 5 of 5 Posts
