1 - 12 of 12 Posts
Senior phuckstick
I have misplaced my build sheet from last year.
I need to know the torque spec on L 19 rod bolts for my BBC. They are a 1/2" Head.
I did a search, here and on ARP's site and can't find anything
Thanks,
Pat
Senior phuckstick
80 lbs sounds familar. I can't even find the paper that came with the bolts. I ususally keep all of this stuff in my car book.
I know it was quite a bit higher than the 2000 series bolts
Master Fabricator
Why not stretch them?
i thought i remembered somewhere not to wash them in a parts washer....also not to contaminate any way. dont know for sure but read somewhere these bolts need special attention....i use them,but didnt assemble my engine
Master Fabricator
You are correct. No parts washer, brake cleaner, nothing. Just wipe them with a rag to clean and do not touch with fingers.
I almost put mine through the parts washer when I got them. Good thing I called Callies.
RED ROCKET
i have always used my fingers on the L19 bolts..been using L19's for over 10 years..never had a bolt failure.everyone says it but i dont believe it...if my fingers can cause a bolt failure i need to use a different bolt.
1 - 12 of 12 Posts
