Kuerig
1323 Views 18 Replies 17 Participants Last post by  jim sciortino
Anyone have the K cup coffee maker? How do you like it?
1 - 19 of 19 Posts
Awesome! For me anyhow. I'm a one cup a morning kinda guy (two at most), so I love mine. Easy, fast and no cleanup.
If you are on well water, stock up on white vinegar!:p
we have had one for 2 years, love it even better now with the refillable filter and fresh ground...much MUCH cheaper than buying the K-cups :drinkers:
One at home,one at the shop and one in the race car trailer,never any stail coffee,buy coffee online at Coffiewiz.com.Bill C.
<----Tassimo brewbot
Got one last week,like it so far.
Love mine, fresh cup of coffee every time. I like the Sumatra dark roast the best. Don't waste your money on the Kenya blend weak stuff just like the Kenyan in the white house.
I have one as well, I really like it. I do run another cup of water through it after my morning cup. Just seems like it keeps it a little cleaner.
Speaking of cleaning it, does anyone have any other tips?
I have one in My office and would never go back but you can plan on spending more money on coffee.
Worked great for first 6-7 months but now the machine doesn't work right (stop mid brew/have to unplug to reset it etc)
Now I have to figure out how to get this thing repaired...may have to go back to the good ole reg coffee maker
Run white vinegar through it. Its probably just dirty.
I love mine.
I have the little one and love it. One cup in the morning and maybe hot tea in the evening if it is cold - which is like twice during the winter in Florida. Absolutely no waste.
Love it, got the special edition they call it, variable cup sizes, makes an awesome ice tea and apple cider.
It isn't dirt. It is scale, minerals and salts in the water build up and it can't heat the water effectively as the scale acts as an insulator. The vinegar is basically an acid wash to remove it. Rinse it well after you descale.
Do you filter your tap water? If not why not buy a gallon of bottled water just for your morning coffee? We filter our tap water and and have not had any problems in the year we have been using the machine minimum 3 cups per day.
I also like the Keurig "my cup" allows you to use regular coffee that you may have in the house if you run low on the single serve K cup type.
I have one, and so far so good. I'm the only one who drinks coffee so it works out great. I got the Platinum one which has adjustable temp, and brew sizes. I want to pick up the "my cup" so I can use my own coffee if I want.
Sean
1 - 19 of 19 Posts
