1 - 4 of 4 Posts
looking for ideas on mounting my Kirkey aluminum seat , if ya have any images please post they .
oh ya it,s a 25.4 car and it,s getting mounted right to the tubing , no spacer/riser between seat bottom and tubes .
thanx
why cant u weld flat brackets off the sides of the tubing and bolt it through the bottom of the seat?
Or use a piece of square tubing cut to a U that's slightly smaller then the DIA of the tubing. That way it sits high and you get full weld potential and still get under it with a wrench to bolt/unbolt if needed.
1 - 4 of 4 Posts
