1 - 3 of 3 Posts
My car used to make 1.49-1.55 60 feet, before the new blower.
I was running a little novi 1220 with 5-6 psi. Now with the Si-trim and 10 psi, it look like the motor build more low end torque..
I wonder if theres a way to take out some timing a bit with the PMS during the 60 feet ?
pig hunter
fit the chassis issue's... you should be able to lay down 1.3's easy with bolt on piece's..... get with trz in the stock suspension setup threads
1 - 3 of 3 Posts
