So as the title says.. I've rolled 2 sprags now on a relatively mild non exotic setup. Its a 1968 Core TH400 with a Jake's performance rebuild kit using borg warner clutches and a 4L80E stack in the intermediate. I have a Hughes forward pattern manual valve body and use Dex 6 fluid. The car is a 74 corvette 5.3 LS engine with a cam, headers, head work, and little nitrous. The first time it happen i raced it a bit beat on it on the street and one day it let go. Then i replaced it with a TCI sprag and changed the bands at the same time and inspected everything and it all checked out good. The second time street driving i got the car rolling in 1st punched it ran it to 6800-7000 rpm slammed 2nd gear and bam it revved to the moon just like the 1st time sure enough sprag rolled. I haven't been able to find any credible measurements of what the inner and out race should measure out at i am curious if when the sprag flipped the first time it shaved a small amount off and now its too loose allowing it to roll easier? just a theory... I have another core here i am going to pull the drum out of its from a 67 truck that had 41K original miles so i figure it has been piss pounded its whole life and maybe the drum and a new 34 element sprag will do the trick. Its no fun not being able to do WOT 1-2-3 shifts. Any help or direction is much appreciated. Thanks in advance
