I have a pair of cheaper turbos and id like to know what you guys think on getting them to spool! the motor is a stock lq4 with arp rod bolts and will be giting a turbo cam I will be using 317 heads with a little port work and running on e85 fuel. here are the spcs of the turbos t4 p trim turbo's 0.68 ar turbine and a 67mm
compressor wheel lmk what you think thanks
