1 - 4 of 4 Posts
Discussion Starter · #4 ·
i have a few different converters. 9 " coan, 9" protorque and 9" PTC. I heard using this fluid instead of atf -f fluid will tighten the converter up(lower stall speed) and lower the slippage at the other end. Really wanted some results if anyone else has tried this and if it did lower the stall. I have one converter i think stalled about 300-400 rpm too high and wanted to see if this would help. the lock up is fine at the other end. let me know what you guys think.
thanks
1 - 4 of 4 Posts
