1 - 2 of 2 Posts
"Made" Member
i here your the 10.5 guru in here. :eek: my car had a 33/15 on it and on a 250 shot right out the gate off the plate it sixty footed around 1.22 w/11 lbs of air in the tire. i just bought 33/10.5w's and they are mounted on 14 inch rims. where should i start the baselines? by the way its a 3450lbs car w/ladder bar and wheelie bar. any info would be great :-D
thanx
corey
I run my 33W's on a 14 inch rim with 10.5 psi of air. My car only weighs 3100lb. Some guys run lower, some run higher. It all depends on the setup. I would start right where you're at now (11psi) and adjust from there. The 33W is a good tire. A heavy car like yours may actually 60' better because of the stiff sidewall.
1 - 2 of 2 Posts
