1 - 3 of 3 Posts
I am looking for same baseline jetting recommendations for my 496. The carb is a Holley 800 double pumper.
The rest of the combo is:
9.8 compression ratio
Cam:
Grind# RH-302-365
RPM Range 3500-6500
Duration @.050 242/250 deg Int/exh
Lift w/1.72 stock rocker ratio- .621 in
Lobe Center 110 deg
Advance - 4 deg
Valve Lash - .000 in
Edelbrock RPM heads, 100cc, 2.19/1.88 valves
Dual plane air gap intake
2" headers
Turbo 400
4,000 stall converter
Ford 9"
3.70 gears
Any ideas to get me close?
76 if it has a PV in front, 84 front and back without will get you started. Still have one I ran for years.
If it is an old one with power valves in both P & S, 72P, 76S. If it has PV in front only 72P, 86S.
1 - 3 of 3 Posts
