I seen lots of discussion on here about jet spread and it seems clear that most are running at least 6-8 sizes smaller on the fuel jet. I have the Performer RPM plate which recommends square jetting (71/71 for 150HP) and 5.5psi fuel pressure.
My Regulator (Aeromotive) can only go as low as 6psi, so I am worried that it will be too rich.
I am going to run one heat range colder plugs and retard the timing 5 degrees, and will run C16.
What do you guys think is a good start for jetting?
