1 - 5 of 5 Posts
When you blowthrough guys change jets, do you up/down jet both the primaries and secondaries together?
i add fuel through pvcr on the primary side and add about the same through the jets on the secondary then it stays fairly clean if i decide to go for a cruise on the street.
It also depends on the carb manufacture.
I keep it square unless you want to street drive alot, then you can split it to keep it cleaner like said above
Interesting. Square jetting seems to make sense. Kevin set it up with 70/79 and a BRPV in the primary.
1 - 5 of 5 Posts
