Jesel BB-Chevy Belt Drive Kit- KBD 32000
Brand New!!
It's safe to say that JESEL is the originator of the modern racing belt drive system.
Cam timing adjustment is made externally providing the easiest and most accurate tuning available.
Billet aluminum Spider is made from 2024-T6 and is available as a solid unit for additional strength.
Accessories available to run distributor drives, fuel pumps or oil pumps off front of cam.
Hard coated Billet aluminum 7075 Upper Pulley features patented High Torq Drive™ tooth configuration.
PTFE® coated high vacuum cam and crank seals.
Patented High Torq Drive™ reinforced belt operates dry and spins with less friction than timing chains or gear drives and also absorbs harmonics.
Crank Pulley is heat-treated steel and incorporates a High Torq Drive™ tooth configuration.
Kit hardware is all Grade 8 Allen and Torx™ head design.
$1000
[email protected]
Brand New!!
$1000
[email protected]
