We have had several people ask for pics of our Adjustable IC Upper Torque Box installed so I thought I would do a build thread on a car we are building that we put them in. There are tons of pics all over the net of our Adjustable IC Mustang lower torque boxes so I wont go into to much detail on them. Feel free to ask questions if I omit something of importance.
Here is the car on the rotisserie getting some trimming done
We pressure washed it and got ready to put it up on the jig table
We have already put the lower boxes in while on the rotisserie since our design only allows the boxes to go in in one place and its much easier to do up there. For those who aren't familiar with them, they are completely tig welded and feature 1/4" chrome moly IC plates, and uses a 3/4" DOM sleeve to bush the rod end to size that allows us to use 1/2" bolts for finer adjustment, and makes the bolt virtually unbendable due to the bolt/DOM sleeve being the equivalent of 3/4" as an assembly.
Since most of the cage/chassis is a design we have built/used before we were also able to fab up the lower tubing while we had it on the rotisserie and temporarily screwed it in place.
We got the car on the jig table and marked the location of the OEM upper control arm hole and transferred it to the rail for comparison later. The boxes can definatly be put in on the shop floor if the car is leveled first, but we were going up on the table anyway so we did it there.
We cut the spot welds and removed the OEM box
We fabbed up a set of our upper boxes. They are completely tig welded chrome moly with 1/4" IC adjustment plates with 1/4" doublers (thats the equivalent of 3/4" mild steel for the IC plates), 11 holes with .300" hole spacing.
Our interlocking design ensures they are completely welded inside and out, even the hard to get areas that some leave unwelded. There are several other places that interlock and weld too.
The hardware for the uppers is 3/4 DOM also
They weigh in at about 13.25 lbs inc hardware
We set the upper boxes in the car for a quick mock up and to mark the areas that needed to be cleaned up for welding
The boxes go up against the top of the rail and back against the floor (roughly only in one place/ self aligning) so we checked that too
And confirmed the OEM hole location to our designated stock hole
Our plated and gusseted design allows for increased weld surface area along the frame rail and allows the box to be trimmed to fit if there is damage to the OEM rails in the box mount area. The boxes are profiled and cut to size as delivered and typically fit as shown. In our mockup cars, they would hold themselves in place without clamps, but we clamped them just in case so it wouldn't fall out on my head lol.
Thanks for your interest it is greatly appreciated!
