it will work well..
as long as you do not run the engine.
I used it in some spots. That was a few years ago and its still hanging in there.Hey guys, can I use jb weld to fix pushrod pinch? If so will it hold up to nitrous and race fuel? Thanks.
although it is tougher than some common epoxy due to the metal matrix mixture,
does not stay "stuck" as well as a common epoxy...
devcon or splash zone or some use Z spar with better results.
...."genuine A + B from moroso" is pretty good too..
this is not to say that I have not used it in a "AT THE TRACK REPAIR"...but I knew that it was not going to be relied upon for more than that days or weekends event...
alky or nitro will dissolve the stuff...!!!
