1 - 8 of 8 Posts
· Registered
Anyone else had problems with "THE WHEEL" flexplate? I found my flexplate ring gear attachment broken in 5 of the 6 welds holding the ring gear to the plate. The 6th weld was cracked. Luckly we found it before it turned into a buzz saw. I bought this flex plate based on its reputation as being a quality item, maybe you don't get what you pay for. What other flex plates are you guys running? I run a SBC with a Motown Block and CSR 2.5hp mini starter.
· Registered
Hi Hutch,
How long does a flexplate sfi cert last from new, & does it vary between brands & materials? Does a re-cert last as long as the original or less?
Do they always have to go back to the original manufacturer for re-certification or can it be done by other sfi certifiers?
Thanks in advance,
Nik.
· Super Moderator
Hi Hutch,
Thanks in advance,
Nik.
Its 5 years and yes it has to be sent back to its original manufacturer.
Hutch
1 - 8 of 8 Posts
