121 - 140 of 176 Posts
Scott
Is that machining on the head surface intake side something you are playing with or is that just the semi-rough before the head is resurfaced?
Scott
That's the "softened" area. It's a 2* "dish" cut into the chamber that effects the quench areas.
Is that something you are doing for nitrous or has it shown other benefits in uses?
It's usually associated with lots of nitrous and higher compression but I think some guys are starting to use it in high boost/big hp apps as well especially with small flat chamber heads with real shallow valve angles.
I know your customer uses a facility that has cylinder pressure data capabilities. Have you tested this mod to see its effect on burn rate?
No, that would mean a before and after. We just don't have time or resources for that kind of testing. Wish we did because I'd like to see that data. On chamber softening, I am 100% just going off what I'm told by others and hoping it works. :-|
Have you guys tested anything like this?
Discussion Starter #130
"It's Time" .. is finally happening!! Thought I'd share a few shots. More to come!
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Discussion Starter #135
Awesome looking components, glad it's coming together, hope it all works out for you.
Thanks! I appreciate it.. been a long wait; had a lot of great help .. can’t wait to get it fired-up and on the dyno!
Discussion Starter #136
your plug wires should be in tomorrow fyi jeff
Thanks Alex! Yep.. they showed up today... appreciate all ur help. Will need some more goodies here soon.
Discussion Starter #137
Discussion Starter #139
Strutted box type pistons then?
Yes sir... with a .9mm total seal ring package. here's a few pics of the custom Diamonds:
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Discussion Starter #140
I don't think that little spring on the front is gonna cut it......:p
What?! ... you haven't heard?!, PSI came out with a new lightweight, low-harmonic single coil valve spring.. capable of over 1.0" lift!! Space-age shyte! :rolleyes:
