81 - 100 of 176 Posts
Nice!
Long Live The King
Are you going to sleep with then under your pillow tonight ? :)
Look awesome ... any flow numbers you can share ?
Discussion Starter #85
Yep, used one as a pillow and spooned with the other one the last couple nights! :)
No flow #'s to share as of yet, hoping to get these soon... well above the numbers Brodix advertises I have no doubt.
Discussion Starter #88
Single cast manifold? Or sheet metal?
Cast ... Super Victor II, Rick is putting some time into it. And I have a new Mark Whitner 1600cfm oval-blade billet carb.. setup for the Q16 I intend to run.
Can't wait for all this to come together.... getting there.
Discussion Starter #89
Well look what Ricks BMF's made at less inches then you!!!!!!
I think it was 585 inches :-Daw
Yep, based on the many conversations I've had with Rick... he's got me pretty pumped to say the least. Bit by bit, this sucker will come together. Pretty sure I haven't cut any corners. :cool:
I hope he fixed the pushrod holes...:rolleyes: Can't even get a 7/16 to work from Brodix, especially on the ex.
Discussion Starter #91
Yeah, I think I remember him saying I could probably fit a 1/2" pushrod if I wanted.
hmm, that's funny , I got straight 1/2" in the one I just did, brodix SR20.
The two ex holes in these heads weren't even pointing at the lifter. I literally could not get a 7/16" pushrod from the lifter to the rocker arm. Intakes needed clearing into the v/c rail for 7/16 like I see in Chris's pic. None of them were even close.
DID you go with a T&D system or Jesel??
I'm curious as the one I did had T&D and I didn't have to touch the Valve cover rail.... this is why I said I think I got a Shit system....
Something wasn't right, the rocker needed set back towards the cover rail but T&D said it was perfect, I disagree....
I only needed a 1/2"-7/16" single taper on the intake per spintron data and Straight 1/2" on the exhaust...
Scott, got any Pics of your setup?
Moderator
Chris,
Is that a One piece stand that fits the hole head including the exhaust under the rockers pedestals?
Does the one piece bolt the head then the pedestals to it....?
That looks like a Bad ass system, Jesel Have a Part Number for it... LOL
It's all 1 piece yes. I don't have a part number for it. ;) I do have nearly 1.200 lift and 260 on the seat however. :D
