1 - 17 of 17 Posts
friends cyl head after pushing 30lbs boost and torching the cyl head and block . new something was wrong when two spark plugs had the electrodes melted off and damage to the porcelain . when the head was pulled you could see were the head gasket got torched and burned thru the cyl head and block deck surface
Discussion Starter #8
Easy fix, very repairable.
Weld it up and mill the deck surface.
ball park price for repair or just get another cyl head .this head has alot of work done to it including oversize valves
It can be done.
Here is a SBC head that dropped 2 valves that I welded couple of years ago.
Easiest thing to do is find someone you trust welding aluminum, and is good. Find pieces of steel or material the aluminum weld want stick too, to fit in the holes that need to pass through. You can weld right up next to the material without it sticking, and pull the material out of the holes once you have the aluminum welded up.
You should expect to pay $200-300 to fix the torched area shown in the picture and flycut the entire head.
Rest of head is OK, right?
Discussion Starter #11
yep nothing wrong with the cyl head besides that area
easy fix
Discussion Starter #14
forgot to mention there a torch mark on the cyl block deck surface but on the opposite side of the fire ring on the head gasket but nothing like the cyl head
1 - 17 of 17 Posts
