I have a new to me Reher Morrison 565 that I bought from a friend. I put it in and ran it two weeks ago and it seemed down on power to me. It only had a few Dyno pulls since freshened locally (story in itself). After a disappointing trip to the track, I decided to leak it down before calling Abruzzi about the converter adjustment. I didn't want to blame the converter being tight if the engine isn't making the power to make it work. It leaked from 6-10%.
I then decided to run it this past weekend. After a little tuning it et'd better but mph stayed the same. I should say that since I fired this thing, it puffs a little smoke on fire up and when I go on the chip. I figured the machine shop missed replacing the guides or it doesn't have valve seals. I decided to race Sunday and when I fired the car in the morning, the puff of smoke seemed a little more prominent. After the 2nd tt I couldn't get the car to cool below 140. After verifying fan and water pump, I squeezed the radiator hose and it was squishy and not real hot. When I carefully popped the fill cap, it FOAMED over. Without the water pump running, I fired the car and watched the water. There was movement. So I'm thinking head gasket(s) and put it away. This week I pressurized each cylinder at TDC with compressed air and could not see any movement or bubbles in the filler. Could this be worse than a head gasket? What are the possible scenarios? Thanks in advance.
