1 - 9 of 9 Posts
Parts list:
MOK W/borg aod 83-90
Filter aod 80-9
Bushing kit fiod/aod
Band overdrive aod 8
Bearing kit fiod/aod
Sprag assy inter aod
Piston dir accum bon
Piston servo rev 3.0
Cover rev servo pist
Valve w/sleeve press
Sleeve tv valve plunger
pin od servo w/o rg
Grommet/clip 4pc pk
Drum rev bear 3pk
The total bill was $1,620.12, which $396 of that was to remove and replace transmission.
The transmission shifts perfect, i just want a t-5.
I also have all of the reciepts
I would like to get $250 out of it, including flex plate, convertor, I'd even throw in the shifter. PRICE IS OBO!!!!!
You are in the wrong section of the forums , this is Trash Or Be Trashed, You need to go to Items for sale:rolleyes:
Parts list:
Filter aod 80-9
pin od servo w/o rg
Grommet/clip 4pc pk
Drum rev bear 3pk
Where are you located?
You paid somebody $400 to r&r your tranny?
If he cant figure out what section to post his sale in, what makes you think he has a prayer of changing a tranny. It is probably a T400 tranny anyway.
This is YB, nothing gets deleted. 2 years from now, when you have 10,000 posts on here, we will still be able to bring this thread up and use it against you. :)
1 - 9 of 9 Posts
