years back some of us local found (when sportsman allowed a button and 4 wheel line lock- aka poor man's transbrake) that we had to use adjustable msd pill so we could not push through the brakes....and I think it was anything below 2800rpm and the cars would load up/kill/backfire/cough when button was released.Maybe dumb question, but is there a point or RPM that is easier or harder on the engine...whether it's "too high" or "too low"?
My dad has used this setup for years in his car with a delay box. Has it set to around 1800-1900. Never really had any issues using it. Biggest thing was just making sure there was enough pump shot in it withthe low rpms.years back some of us local found (when sportsman allowed a button and 4 wheel line lock- aka poor man's transbrake) that we had to use adjustable msd pill so we could not push through the brakes....and I think it was anything below 2800rpm and the cars would load up/kill/backfire/cough when button was released.
No such thing as "too high" really since too high is taking pill out and going straight on convertor...which surprisingly a lot of people do.
Related question... when foot braking, would a lower RPM give a better 60 ft ? I have the 4wheel linelock setup and it did a 1.62 with 2 step set at 3500. The converter flashes to around 4500-5000. My buddy suggested dropping to 2500 to give a harder hit.I leave on the mat with adjustable chip at 2200- 1.57 60ft no problem. I foot brake and much higher it wants to push through brakes.
Depending on the converter, yes it should leave better. I leave at 2200 off the footbrake and it leaves higher/harder than 3500.Related question... when foot braking, would a lower RPM give a better 60 ft ? I have the 4wheel linelock setup and it did a 1.62 with 2 step set at 3500. The converter flashes to around 4500-5000. My buddy suggested dropping to 2500 to give a harder hit.
Very well said. I should have added that in my comment. Don't m is about everyone else, my car is for every 200rpm (+/-) is worth around .015 in RT. If I leave at 3200 and I'm .490 red I drop down to 3000 and generally .005 to .008 (on paper)Might slow rt slightly.
