1 - 6 of 6 Posts
· Registered
Well heres what i got rear to front,
-12 from sump to Magnafuel 500
-10 from Magnafuel 500 to Aeromotive A2000 13202
-10 return from Aermotive A2000 1320 to cell
The Aermotive A2000 13202 has 4 ports.Pressure is set at 7 1/2 psi
2 ports are feeding the carb.
1 port is feeding a Holley 803 which is set at 6psi and feeds the nitrous fuel side.
Is this setup ok or are changes needed?
Thanks!
· "Darkness"
You have enough pump without a doubt. I have never fed a regulator from another regulator. But I would assume if the volume and pressure supplied to the nitrous fuel reg was enough then it should be fine.
· Registered
Discussion Starter · #4 ·
The Magnaful 500 feeds both the motor and the nitrous.The carb and nitrous require 2 different pressures so that why i got the 2 regulators.Is it bad to feed one regulator off the other? I dont wanna melt down my new nitrous motor!
· Registered
Heres how I did mine -10 feed to a y-block then -10 to each regulator one for engine one for nitrous, the ran a -10 return for the engine side regulator only.
1 - 6 of 6 Posts
