1 - 20 of 70 Posts
427 SBC
23 degree Profiler All American X CNC (235cc port) heads
Edelbrock Super Victor 2
285/[email protected] .50 Duration 684/657 lift 1.6 rockers
950 cfm carb
4.56 gears
28" tires
2800lb car
Makes its power starting at 6700 to above 8000
Are these heads too big for a 427 sbc? The reason I'm asking is I had a 6000 stall converter built by a well known business but I can't get the thing to stall over 5200 on the trans brake. The car also doesn't flash from 3800 2 step launch, it just steadily climbs from lauch. Which is what it did with my previous converter also. I told them what was going on and they told me every 427 in their records works well with the same converter or one very similar getting 6000-6200 stall. I'm getting 900-1000 rpm drop during shift so they don't think it would be a good idea to give it more stall. Which I agree with. Which leads me to believe I have no low end torque.
Lot of duration and not much lift.
A bracket 421 I rebuilt used a 275*/280* @ .050" .700"/675", 106 separation. RHS 235 heads 2.08" intake valve. Ported by Jones.
Why did that cam get chosen and by who?
Herbert Cams recommended it.
You could call Kirk Milner at Bullet Cams. Easy going knowledgeable cam guru. Going to cost you more than a Herbert cam, but how did that work out?
Are you sure your cam specs are 285/295 at .050" lift and not .020" lift?
Everything else in the list you presented makes sense.
Discussion Starter #10
Yeah, I have the card and box it came in, it's definitely @.50
Like others said , a lot of duration. Only way to find out is to put something smaller in the engine.
427 SBC
950 cfm carb
4.56 gears
28" tires
2800lb car
The problem is not the cam. I had a 305 cu in engine with a similar size cam and it ran good. You have other problems. I can’t imagine an engine with that much cu in needing a 6200 converter. That being said it’s probably not the best cam selection and it will need some rpm to run. How did you degree the cam. I would say you need to have it installed at about 102 CL. The cam should also have a 106 love separation. Did you check piston to valve clearance when the engine was assembled. Who built the converter.
I have a brand new small base circle Solid roller 274/282 .460/.450 112+4 cam motion cam for sale would be a good option in that thing. I’d let it go for $220 shipped
Discussion Starter #14
I didn't degree the cam. Cam is installed it straight up. Cam card says it's got a 116 lobe center and 112 center line. I don't remember the valve to piston clearance but is was enough that I have nothing to worry with the current lift. Converter is a Coan.
There you go ...... wide LSA cams are soft down low.
  • Like
Reactions: bigcam406
YB Liar and Chief
If compression ratio is below 13.5 or so its going to be a turd with that bumpstick.
  • Like
Reactions: Horndog
1 - 20 of 70 Posts
