1 - 8 of 8 Posts
ok dudes and dudets
does the g-body cars work better stock suspension with all goods work better then ladder bar with all its goody. d adj shocks all around, anty roll bar, ? let it fly
Roger
If you do it right with the stuff out there right now a four link (stock), will be as good or better than the ladder
why is one better thin other? do the tire make a diff. DR/ slick on what susp. u run? if u was choosing the susp. for a tire u running
Roger
if on g-bodys getting the ic forward and low on stock susp. how can a ladder bar with the ic so far back work so well? or am i lokkn at it wrong?
Roger
I lot of times the ladder hits the tire to hard. NOT ALWAYS! "just to ward off the haters"
Radial or slick doesn't matter to me, keep it s/s and don't look back!!
Discussion Starter #8
how low to the ground is most high HP? say like the front frame bolt on rear lower bar to the ground? with a 295 DR tire
Roger
1 - 8 of 8 Posts
