1 - 1 of 1 Posts
Hey guys I sent my ati converter out for a winter frehen up and now that I have it back I have. Bad oil leak I'm the front of the trans. The pan and bottom of the ultrabell are wet. I haven't started it and can't see with a light. But are a pg input and th400 the same od where they ride the seal. It almost looks like the snout is smaller than the seal in the pump. Also the new pilot they installed has a step on it and I can't seem to get it to line up with the crank as easy as it should. I measured piolot at 1.7 and crank at 1.7 that wouldent work right it would have to have a few thou gap so it could go in. The tranny has all new gaskets and seals w 0 miles on it. Tranny I took out ran for 13 yrs ann never a leak till I got the converter back. I've ran w this converter for 4 yrs. Never once had a install issue or leak.
1 - 1 of 1 Posts
