1 - 5 of 5 Posts
"Made" Member
is a 6 quart oil pan and 2 quart filter enough oil?? i just bought a kicked out moroso pan and it only holds 6 quarts of oil and i have a remote oil filter that holds 2 quarts of oil, the reason i didnt go bigger is because in the past ive smacked the oil pan on the ground several times...... do you guys think this will be enough oil?? its a 555 w/2 stages of nitrous.....should i just over fill it a quart or will that make a mess and not help anything?
thanx
corey
You're saying eight quarts total?????that should be more than enough.external pump??"we" usually run 6 total in a small block with a "big pan".
1 - 5 of 5 Posts
