I picked up a GM iron 6.0 that was burnt pretty good, Hot enough to melt the aluminum valve covers but aluminum heads and water pump/ front and rear covers/oil pan are still whole. The only thing I want to reuse are the block/crank and maybe rods and pistons. I already have the heads off and other than some surface rust (no pitting) the cylinders look ok. I just wonder if the heat would distort the block to the point that it's not feasible to use it again.
