1 - 4 of 4 Posts
Any of you guys know off hand why the light is staying on ? Maybe ignition i was thinking...Thanks
If you have something like low oil pressure programmed and have not added engine RPM above 500 as a second parameter, then the warning should be on as soon as it gets power. Depending on how it's programed, it should be flashing the title/item the the warning is referencing.
1 - 4 of 4 Posts
