1 - 6 of 6 Posts
Hey Jim. Do you run an intercooler on the turbo car?
Mark
Thanks Jim. If memory serves me correctly the Chevy II did not have one. I would have to assume this is due to the outlet temp on the compressor side of the turbo is greater then on the procharger?
Do you figure all turbo/blowthrough combos require an intercooler?
Much obliged.
Mark
TURBOBULLET.COM BITCHES!
And also, would a Air/Air Precision turbo core that is rated to 1700 hp be a good choice if running a PT91.5?????
Thanks.
Thanks.
a2a won't be as efficient as a a2w...more pressure drop and probably won't get the air as cool either. I'd go with an a2w especially for a racecar.
1 - 6 of 6 Posts
