1 - 5 of 5 Posts
Intercooler should be here in a few weeks (No Corners Cut Fab 2500HP). Need to start thinking about plumbing it. Looking for suggestions on:
Hose/fittings
Hose size
Pump
I have seen some more cost effective options on running a push on barb style hose that I would like to explore if possible.
B
I run a rule 2000 with 1" and it has worked well for me for the last 4 years. Some guys swear you can't run tight bend fittings etc. Due to where/how my IC is mounted, I was forced to run 2, 90* fittings in/out of the IC itself. It has had no issues keeping the iat's in check even on a 90*+ day.
It's one of those deals where it's optimal not to use any tight fittings. If you have to, then you have to. But more water flow = more cooling and fittings (especially plumber style tight elbow ones) kill flow.
1 - 5 of 5 Posts
